Browse Forums Building A New House 1 Oct 12, 2023 6:32 pm Hi All ,
Need some feedback on the split level design we have pulled together as a concept plan. There are limitations around cut and fill therefore we could not put any more rooms behind the garage leading to stairs going up. Floor PlanConcept floor plan of split level design.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New custom build - Floor plan - Need feedback 2Oct 16, 2023 1:18 pm Prats09 Hi All , Need some feedback on the split level design we have pulled together as a concept plan. There are limitations around cut and fill therefore we could not put any more rooms behind the garage leading to stairs going up. can you share your house plans for feedback Re: New custom build - Floor plan - Need feedback 4Oct 17, 2023 1:07 pm Prats09 attached to original post now. there seems to be inconsistent overlaps between the different levels and all dimensions are not clear so my suggestions are based on approximations and, depending on the orientation and size of your block of land (ie views, distance to neighbours and direction of sun) all the windows and sliding glass doors need to be carefully checked and depending on the slope and access to the outside drying areas and distance to side fences it may be cheaper and easier to walk through the house rather than exit through an external laundry door to a steep side path with steps and/or could the laundry be better placed upstairs and the existing laundry and entry could make an alternate media or guest room.....lots of options but i'm having difficulty uploading my revised floorplan so will do so asap Re: New custom build - Floor plan - Need feedback 5Oct 17, 2023 1:17 pm Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. Re: New custom build - Floor plan - Need feedback 6Oct 17, 2023 1:23 pm Prats09 Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. yes please...include direction of north and any views as well as approx distance to all boundaries... i've done a rough draft of my suggestions but having problems uploading Re: New custom build - Floor plan - Need feedback 7Oct 17, 2023 2:43 pm oklouise Prats09 Thank u ... will be keen to see your changes. There is only a 1.5 m slope upwards on the building envelope so not too steep. The highest point is at the top far ocrner of the block and we will be atleast 10m away from it. I can send you a draft site plan if that helps. yes please...include direction of north and any views as well as approx distance to all boundaries... i've done a rough draft of my suggestions but having problems uploading attached first variations Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12874 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25559 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 21209 |
