Browse Forums Building A New House 1 Apr 29, 2024 9:14 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First time building. this triangular part (marked in red) behind my two bedrooms does not have external wall bec of Alfreco roof covers this area Areas above this roof are covered with hebel external wall any reason why this triangular part external wall is left opened to Alfresco roof . I know the inside will be gyprock. you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3863 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 9549 |
