Browse Forums Owner Builder Forum 1 Nov 07, 2018 11:27 pm Hey, So basically i want to relocate the grounding rod for my home and i really don't want to shell out like $500 to an electrician to do something i know i can do with my eyes shut. My home is around 100 years old an inter-war period home, it has a very tiny entrance with steps leading right down to the street, this means that over the years all the services have been poorly shoved in the tiny entrance of the house. Including the grounding rod which is in a small planter box next to the stairs at the entrance with a big ugly pvc pipe running across the porch and up the wall containing the wire for the rod. Basically i want to pull out the rod from the entrance of the house and run it from the breaker to under the floor and into the ground under the house somewhere. So just wondering if there is anything wrong with re-locating the rod to under the house in the centre of a room? instead of having it located pretty much on the street? There is more than enough length on the wire to do so and about 1.5-1.7m clearance under the house. I dont believe there is any danger as the wire was originally located in the entrance of the house within arms reach or every person walking past on the street and everyone using the stairs. So as long as i turn off all the power and make sure i do the work on a sunny day with no storms / chance of lightning i should be sweet? Thanks for your thoughts. Cheers, Davo. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18305 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36544 |
